Help Me...import sketchup to archicad
hi guys...I'm nubie using archicad...i'm using archicad 12...and my question is " how to import sketchup file to archicad?' i'm downloading sketchup add on..but when i'm opened skp file in to archicad i had an empty file... does any one here can help me? plzz...it's means a lot for my project...thx's all
7 Replies 7
TMA_80
Which plugin have you downloaded?
AC12_27 |Win11_64bit|
i'm using sketchup 7 and archicad 12 windows xp sp3....thx's
TMA_80
There are two Sketchup plugins for ArchiCad12...
Anyway, try to save your Sketchup file as skp version5. ( The Sketchup plugin has a problem in importing any newer skp file version than that)
then try to open it again in ArchiCad...
how can we know about which plug in we used...? thank you
TMA_80
so if i'm not wrong:
If you install this one it will open directely from file / open ( *.skp should appear as a file format choice ) this will transform any skp surface into walls, slabs, roofs...
however, if you install this one it will open directely from file / open ( Google WH Sketchup .skp should appear as a file format choice ) it will import directely your skp file as an object
In both cases, save your skp file as skp 5th version before importing in Archicad
I Try both of them ( Plug in )...and save file to .skp 5...but the file was empty when i opened in archicad 12...sometimes when i'm opening skp file with archicad 12..there was a bug reporting.... thank you all...
TMA_80
I can't help then ...
ok, a last thing 😉 ,you could check your model with zoom options : click on fit to window , zoom in and out...etc...it could be possible that your model is either too small( far) or too big ....
