Hi question about 3d dwg/dgn files
Hi
this question has probably been answered before im sorri for this
is it possible to model in microstation or autocad dgn or dwg and import the 3d object into archicad?
if anyyone knows how to do this please help.
thank you for anyhelp
DunX
6 REPLIES 6
Go to File -> GDL Object -> Open Object -> pick DWG format.
Sometimes, for some reason it does not preserve 3D data so it is much better to use 3ds import.
Cheers
Djordje
thank you for your replies following the guide in the link however i do not have the open library part option in under file. i have attatched a print shot of what i do have.( i tried but it doesnt atatch which file format is best i saved it as bmp)
i have also tried the shift ctrl option O although i dont know what key option is im guessing its alt or tab, on windows neither work.
thankyou for your help
try the screen shot again here we go jpeg works thank you for your help guys!
the one posted in the guide shows it like this
DunX
It's probably just an earlier version of Archicad. (...ArchiGuide_Online_6o...= AC6 I'm guessing), but you're heading in the right direction in your screenshot.
