Hotlink Module Roof Surfacer
Working in ac22 and have a file with a site (parent file) and 3 building files (children) hotlinked into it. One of the buildings (child) has a standing seam roof created using the roof surfacer tool. However it doesn't show the standing seam roof surface when you hotlink it into the site file (parent ). The roof structure and the roof surface are on the same layer In the building file (Child) but only the roof structure shows up in the site (parent file). Any ideas or work around out their.
4 REPLIES 4
Guru
Is the Roof Surfacer Object there and just not generating?
The roof surfacer tool is a library object.
Is that object in a loaded (linked) library in your master file as well?
I will need to double check under the gun with a deadline at the moment so will get back to this in a day. Thank you both for your reply's will keep you posted.
You nailed Barry, did have the accessory library loaded in the master file. Thank you very much Jim
