4hotshoes
How can I copy a schedule's format between projects
I have several schedules that were successfully created on one project and now I would like to update my new template. Is there a cut and paste or export-import?
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
1 Reply 1
Steve Jepson
Import -Export
You can import multiple Schedules at one time also. No risk of duplication because the program will automatically add a number to the name of the Schedule if it is a duplicate. If you import a Schedule from a newer version of the program to an older version a warning will pop up to let you know that you may need to check the schedule for fields that may not be available in the older version.
