How to Calculate the length of a rafter????
I have taken the Archicad Roof Maker library and copied it to my own custom library. I have removed the calculations that were created by the part already. I want to create a variable similar to what has already been done, but I want the calculation to show up in the new variable using a parameter script so that I can use it in a IF THEN statement in the properties script. I have thought about pythagora's theory and SOHCAHTOA, but I cannot find a formula that will place the calculated value in the varible I have created. Should the variable be a text, integer, or a real number? Any ideas would be greatly appeciated. Thanks.
Barry
4 Replies 4
Steve Jepson
Like this?
I am not sure of how it should be programmed in GDL, but the equation you are looking for is as follows;
Rafter length (along slope) = Rafter length (on the flat) x Secant of pitch
where Secant = the inverse Cosine (1/Cosine)
or more simply
Rafter length (along slope) = Rafter length (on the flat) / Cosine of pitch.
For example to work out the rafter length of a rafter spanning 3.0m at a pitch of 15 degrees
RL = 3.0 / Cos 15
I hope this helps
Steve Jepson
I see my last post did not have the attachment.
Is this what you want?
I'll give it a try. Thanks.
Barry Halloran
