How to: Not schedule empty openings Doors and Windows (ArchiCAD 22-5003 Int Full)
3 Replies 3
This step not active in ac 22
Change the “Criteria” to “is not” (this excludes stuff). Click on the value button (3 dots) Please note: it might take a little while to open up the next window depending on the size of the loaded library. which will open up list “Library Parts”
Thank you..
It seems the 3 dots are no longer there (version 22).
However, you can just type the name.
Post moved and duplicate deleted.
Please try to post in the correct section and please do not post the same question more than once.
