How to create DXF file with sections, stories, & elevations?
I need to send my engineer a DXF file that contains all of my layers, sections, stories and elevations. I quickly figured out how to incorporate all of the layers, but I have been unable to figure out how to incorporate the other three. I am using Archicad 13, student version.
Thanks,
Spartan
3 Replies 3
A student sending files to an engineer
You will need to send each storey, section elevation view as a separate DXF file.
This can be automated in Publisher so you set the views up once, set them to publish as a DXF and then just publish that publisher set when ever you need them.
There is a new feature to merge DWG/DXF files when publishing them but I think this is a version 14 feature only and i haven't explored it so don't really know how it works.
Another option wmight be to creat layout pages of your views and publish those as DXF.
Thank you Barry.
I just sent my engineer a zip file with all of the relevant stories and sections.
In response to your comment "a student sending an engineer..." I recently enrolled in a local community college to learn about building science (I also took an Archicad class) and set about building a home for myself and my wife. You can see plans and details at our blog: http://spartanandhannah.wordpress.com.
Spartan wrote:
Thank you Barry.
Good to hear that there is a community college teaching ArchiCAD. Enjoyed browsing through your blog, Spartan, and congratulations for what you've accomplished. Good that you've gotten a structural engineer involved.
Do feel free to post any questions on the appropriate forums here if you have any more.
