2023-05-18 10:53 AM
I'm fairly new to Archicad 26 and was wondering if there's a way to save my textures so I don't need to keep recreating them each time I start a project?
I have attached a screenshot of what the Surface Settings shows me.
Thank you in advance,
Sophie
2023-05-18 10:55 AM - edited 2023-05-18 11:00 AM
You can use the attribute manager to transfer your textures into your template file. You just need to ensure you are loading all of the relevant libraries.
Other than that:
Options => Element Attributes => Enable Saving a Surface as GSM
Options => Element Attributes => Surfaces => [Relevant Surface] => Save as GSM
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2023-05-19 03:31 AM
Terminology is critical here.
A texture is an image file used by a surface material for viewing in 3D.
These texture image files just need to be located in a loaded library for your surfaces to have access to them.
Surface materials are attributes.
You can use the Attribute Manager to transfer them from one file to another.
