ID field character limit
Currently the element ID field is 15 characters long. I am attempting to compile a construction kit of favourites which will cover the domestic work which makes up almost all of my workload. I would like each favourite to have an ID where:
The first three characters are a Uniclass schedule G ref; the next three are a Uniclass schedule J ref, and then say fifty characters for an abbreviated description. In this way I can compile lists and schedule according to Uniclass elements and include a direction to the materials & workmanship spec via the sched J portion while critically allowing the builder to recognise the nature of the element from the drawing label. So, Graphisoft, what about a 64 character ID field.
4 REPLIES 4
DGSketcher
Legend
Add this to the wish list! It would get my vote!!
The wish where people can vote:
http://archicad-talk.graphisoft.com/viewtopic.php?t=48560
Tim Ball
You could use an IFC field that you create yourself instead of the ID field. Then you have 225 (or is it 255) characters to play with
Tim Ball
AC26, iMac
User since V5
James B
The 15 character limit to the ID no longer exists in ARCHICAD 19.
As indicated here:
http://helpcenter.graphisoft.com/guides/archicad-19-int-reference-guide/archicad-19-new-features-gui...
Under: Show Full Element ID in Zone Stamps
James Badcock
