I'm using the round trip to confirm the output of the IFC format. Before I go trying to share the BIM with others I felt it was important to be able to share it with myself...isn't is a big ask to expect someone else to be able to open a file format if you can't open it properly yourself?
I'm currently working with Graphisoft Australia and CadimageTools on the problem and between us it has been identified as a problem with the reveal settings on the Door and Window Builder windows. I'll post an update once we find a solution to that.
The other part of my question still remains however...is there a better way of setting up and editing the IFC Custom Property Set Configuration File? I'd really like to hear from anyone involved with either using the Configuration Files (or even better from someone from Graphisoft responsible for the creation of the process). Can there be a better way of adding new properties to an existing Configuration File?
Matthew Johnson - POWE Architects
AC4.5 --> AC27 & Revit 2019 --> 2023
Asus Zenbook Pro 16x i9-13900H w/ Nvidia RTX 4070 4K dual, Windows 11 64bit
I'd rather be sailing.
