Hi Chirstophe!
Yes, I have already tried that. What I mean, is that there are some factory default mapping rules, for example, as for beams:
"Examples for factory default mapping rules for IfcBeams:
- The Name Attribute is derived from the ARCHICAD Beam-classified elementās ID parameter (found in the Categories and Properties panel of Element Settings).
- The value of the IsExternal property (Pset_BeamCommon), either āTrueā or āFalseā, is derived from the corresponding ARCHICAD elementās Position classification (either āExteriorā or āInterior
- The value of the LoadBearing property (Pset_BeamCommon), either āTrueā or āFalseā, is derived from the corresponding ARCHICAD elementās Structural Function classification (either āLoad-Bearing Elementā or āNon-Load-Bearing Elementā).
This is an example, using the ArchiCAD template:
I think that Reference (Pste_BeamCommon) is using a factory default mapping: Material + cross section
I would like to know all the factory default mapping, and if we can modify them, because I havenāt found anything in the translators.
ArchiCAD user since November 2109
AC24, Windows 10
