IFC Import does not support Revit parts.
As stated above. It's a bug since the viewers like DDS can see the parts without a problem.
4 Replies 4
Djordje
Is Graphisoft IFC export addon installed in Revit?
It does not necessarily have to be a bug ... which translator are you using?
Be aware that Revit and Autodesk software in general are not the world champions in IFC ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Have you update with the latest ifc-update for ArchiCad?
And like Djordje said, Autodesk products doesn't always export their data correct, even if DDS could read them.
Miki, can you provide some more info about this problem?
Maybe a screenshot.
Guys at GS might be interested in it.
Now this got really interesting. I used the same files as previously and this time around it worked.
I think the difference was the updated IFC plugin (3434).
It converted all slab parts into objects though.
I have just updated to 3602 and it works too.
There should be a not on the IFC page that the latest version of the IFC plugin is available with the Hotfix 3602.
