Aaron Bourgoin
IFC Mapping Properties for Export & Predefined Types
I’m going to use the IFC Type IfcDistributionChamnberElement as an example.
The Archicad Classification 2.0 system has an identical Classification to map the AC to the IFC classification types.
The IFC Type Product - IfcDistributionChamnberElementType - has a drop-down list of Predefined types and any one of our projects, it’s certain that we will want to assign one of these Predefined types to elements in the building model.
What do I need to do in the “Map IFC types for Export” dialog so as to enable a selection from a drop down list when editing a specific instance of the object. As the two images suggest, I'm not seeing the option selected in the Map dialog when I open the Edit element dialog.
Thanks for your help.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.32 Mac
MacOS Tahoe 26.5.1
9 Replies 9
Miha_M
Type Mapping for IFC Export (Graphisoft.com), this one is for AC24, but should work in all other IFC BIM enabled versions.
| Archicad 4.5 - 29
Aaron Bourgoin
Posting a response I got in another forum from Nando Mogollon:
Hi Aaron,
In short, there's nothing you can do to make that "greyed-out" field to be a drop-down list. The predefined type can be changed but in a different way.
Indeed intuition dictates that the option should be available from the Element's Properties panel. My understanding is that it is not selectable ( as drop-down list or else) from there is because its type selection is driven By the Archicad Classification System.
So, to get the Predefined Type (ifcDistributionChamberElementTypeEnum) to read the desired type in the Properties and therefore in the exported IFC, you will need to classify it (Archicad Classifications) with one of the sub types (Manhole, Trench, InspectionPit or whatever). Then the Preview Translator will make the Element to display the correct match in the Predefined Type (in the Properties tab/window)
A couple of notes:
The current Archicad Classification system is a direct match ( not 100% but close) to the IFC4 list of entities and predefined types. Note that if using IFC2x3, predefined types are set to Userdefined /Object Type, not predefined types
 In the case of requiring other sub types  (not pre defined but User defined, then just create a new Archicad Class for it, and map it to the Translator/Map IFC Types...
Rhino 8.32 Mac
MacOS Tahoe 26.5.1
I have to be honest with you and say that I build my own Classification System as a 1 - 1 match of all of the IFC4 ProductType options. This way I can set up my translators for a 1-1 import and export also. The current Archicad Classification System by not covering everything means you need to add to it to make it meet your needs. Hence why I went with a different approach of creating mine from scratch.
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC29 | WIN 11 | Ultra 9 285K, 3.7Ghz | 64GB Ram | RTX4000
Benjamin Dani
Dear All,
Thank you for sharing your ideas and opinions regarding this request!
I'm glad to say that we took notice and we have added this wish into our Wish list database.
(For future reference, you can refer to it as IDEA-12375)
I hope we see this get implemented in the future.
Have a great day!
Best regards,
Dani Benjamin
Technical Support Engineer
Tintifax2
... same thought, less ambition.
Frank Beister
Yes, that seems helpful, but unfortunately it is incomplete. Someone must have created this in the template at some point, but then no longer maintained it. In addition, there is no automatic link between the comment and the type assignment actually used or set.
Tintifax2
retracted (why can't I just delete this?)
davdelven
Where is that Wish list database including the IDs: i.e. IDEA-12375, etc?
Is it available to us to check its progress or updates?
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
It is an internal database used by Graphisoft people, mostly Product Manager, it is not available for users. It had information value prior to the Wishlist Spring Cleanup.
