IFC Zone Height when Imported in Revit
Has anyone discovered the solution in opening IFC to Revit where Zone will have the correct height settings as per AC and not having default height by 8 feet / 2438.4mm?
Zone height in AC = 3000mm
Exported in IFC and opened in Solibri = 3000mm
Opened in Revit with and without Connection Add In = 2438.4mm
1 REPLY 1
I think you would be best asking on the Revit forums but this issue has already been raised with no answer ( https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles... ), interoperability not typically an issue for Revit users because “if you’ve not using Revit you’re not really using BIM” :
