IFC link, unlink
Is there a way to "unlink" an IFC file from an archicad file. The IFC file generated in Revit by the structural engineer has brought with is several added stories and wreaked havoc several of the plan views, specifically roof and site plans. Any thoughts are appreciated. My hope for now is to just eliminate the IFC model information from the file.
Thanks!
7 REPLIES 7
You may have to manually repair that file by deleting those created Stories, deleting those created Layers and IFC elements.
For the future if may be a better idea to import the IFC into a new file, then place that file in your porject as a Hotlinked Module.
Generally, IFCs are best used as Reference Models, where the Architect, Structural Engineer, MEP Engineer, etc. all work on their own model and use the others' models only as Reference model.
You can read the ARCHICAD Guide for more information about this:
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/interoperability/multidiscip...
KenMcN
laszlonagy wrote:
…For the future if may be a better idea to import the IFC into a new file, then place that file in your porject as a Hotlinked Module.
Does that sidestep the problem when third party files have different story settings from the host?
I thought the linked model would always move its elements up or down to match the stories in the main file, usually making a mess of the model.
We've got this problem with a development as the Revit users have added stories to suit themselves, meaning that we can no longer just bring their model into ours.
I've tried converting it into a library object but can't position it accurately (can't snap to anything), so thinking that we may have to go to Solibri to continue to work with a federated model. Not great.
Kenny
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
Even if you open the IFC in another file and Hotlink that, you will still have to deal with the problem of different Story structures just as you would in case of any other hotlinked module.
With regards to the issue of additional Revit levels these additional levels can be toggled off at the Revit users end prior to exporting the IFC file.
Simply view either an Elevation or Section within the Revit model and uncheck the Building Story attribute. This will stop the additional structural levels from being exported with the IFC file.
KenMcN
Don't want to hijack this thread, but in our case the other architects have said that because these are 'real' stories and not 'reference' stories they don't have the option to turn them off. So does this apply to all stories irrespective of how they have been made? Hope so!
Tim Ball
Surely this kind of thing should be agreed as part of the project BIM protocol. It's a nonsense to be working with different storey setups! You should not have any unreal storeys in a building, they either exist or they don't!
Tim Ball
AC26, iMac
User since V5
KenMcN
Yes, it was "agreed" in the BIM Protocol a long time ago, however the Technical Architect is also the BIM Manager and has decided that their interpretaton of a failry general description of the floor levels alows them to do this.
The new stories are areas where the FFL is different to the main block of accommodation, so technically they do exist, just not for every 'block' that makes up a very complicated development. No real option to divide them into totaly separate files as they overlap so much.
Frustrating.
