‎2015-05-14 10:28 PM
‎2015-05-15 02:50 PM
‎2015-05-15 08:27 PM
laszlonagy wrote:Does that sidestep the problem when third party files have different story settings from the host?
…For the future if may be a better idea to import the IFC into a new file, then place that file in your porject as a Hotlinked Module.
‎2015-05-16 01:02 PM
‎2015-05-17 02:03 PM
‎2015-05-17 06:24 PM
Marcus_Scott wrote:Don't want to hijack this thread, but in our case the other architects have said that because these are 'real' stories and not 'reference' stories they don't have the option to turn them off. So does this apply to all stories irrespective of how they have been made? Hope so!
With regards to the issue of additional Revit levels these additional levels can be toggled off at the Revit users end prior to exporting the IFC file.
Simply view either an Elevation or Section within the Revit model and uncheck the Building Story attribute. This will stop the additional structural levels from being exported with the IFC file.
‎2015-05-26 06:34 PM
‎2015-05-26 06:48 PM
Tim wrote:Yes, it was "agreed" in the BIM Protocol a long time ago, however the Technical Architect is also the BIM Manager and has decided that their interpretaton of a failry general description of the floor levels alows them to do this.
Surely this kind of thing should be agreed as part of the project BIM protocol. It's a nonsense to be working with different storey setups! You should not have any unreal storeys in a building, they either exist or they don't!
