davdelven
IFC4.3 TC1 (4.3.0.1)
Hello, @Minh Nguyen and others responsible for the topic
As long as the IFC schema has evolved during the last few years, including new domains but also refining the building one (including Architecture, Structural and Distribution elements, see IFC4.3.1.0 Documentation (buildingsmart.org - Updates from 4.3.1.x might be used as input into the I..., I'd like to ask which is the plan or the roadmap milestone to implement import/export for the IFC 4.3 TC1 already in ISO voting process.
We'll stay tuned for your feedback,
Kind regards,
David
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
4 Replies 4
@davdelven Minh is no longer with Graphisoft.  But, your question will perhaps be answered in a little over 12 hours at the online Building Together event on Digital Collaboration:
https://community.graphisoft.com/t5/Graphisoft-Insights/Building-Together-Collaborate-Digital-Event-...
Hopefully, if you are not already registered, you might see this message and register in time to attend and ask your question in the text chat, just in case it is not addressed.  The agenda shows 30 minutes at the end for live questions and answers.
davdelven
Thanks @Karl Ottenstein
I wasn't aware of today's event. I'll try to jump in and ask for this an other requests.
Thanks for replying and update about Minh, as well.
KR
David
davdelven
They gave an answer, somehow like:
Carlos Cordeiro said: "The IFC4.3 is mainly focused on Infrastructure domains, and Archicad is just for building domains. We'll stay focused on which are the workflows that our users demand from the building domain that requires the use of an extended version of the current IFC4 ADD2 TC1, for future implementations."
In my opinion, they should not forget that IFC schema progress has a domain accumulative model. That means the building domain is also evolved in newer versions. Only due to that behaviour, the latest version should be always included as a high-priority feature to implement.
We hope to see soon also bSDD and IDS implementations. AECO industry is moving, and Architects' reality is too.
brevai
'IfcBuildingElement' supertype also changed to 'IfcBuiltElement' in IFC4X3. So upgrade is a must for further compatibility.
