Import 3d Revit, to get to artlantis.
I looked for a post on this, but didn't see at first any comments on the subject. If there are posts on this subject please direct me to them, if not does anybody have any idea how to import (3d)revit to archicad. I am currently working with revit to dwg, open dwg as library part, then export to artlantis. The end game is to get a working model into artlantis, from our consultants to match our artlantis work.
Djordje
Why don't you just open DWG in Art•Lanits? If Art•Lantis R, you open it as an object, and you can reposition it, and so on ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I would suggest importing Revit into ArchiCAD via IFC file format (or skip Revit and build model in ArchiCAD). We are importing Revit Structural files successfully and all the 3D steel data is attached to our Architectural model.
Brett
Connolly Architects, Inc.
Milwaukee, WI
I too am having problems importing a Revit file into arcihad. I am trying to bring in a surrounding buildings done in Revit. Any ideas?
