2009-06-30 09:39 PM
“Architect shall describe internal abilities to produce the project in software compatible with AutoCad MEP 2009/Revit2009 software, as this may be the preferred software package for the project.”Archicad needs to develop an import/export for Revit files immediately. I can say for a fact. If my office is told we did not get a job because we were not on Revit...Goodbye Archicad hello Revit.
2009-07-01 08:18 AM
		2009-07-01 01:27 PM
2009-07-01 01:55 PM
jorgec wrote:As I already pointed out in the other thread, it is more than likely not possible, due to the fact that Native Revit Files (.RVT format) are a closed format - just like Native ArchiCAD file format ( .PLN) is also closed to be readable by and writable from only ArchiCAD.“Architect shall describe internal abilities to produce the project in software compatible with AutoCad MEP 2009/Revit2009 software, as this may be the preferred software package for the project.”Archicad needs to develop an import/export for Revit files immediately. I can say for a fact. If my office is told we did not get a job because we were not on Revit...Goodbye Archicad hello Revit.
I know Revit is not any better and it seems I spend a lot of time convincing my supervisors that Archicad is the right solution for us...But my friends, we lose a job because of this.
2009-07-01 04:14 PM
Holger wrote:One problem: IFC only has the model. I think the goal here is to be able to open details, sections, sheets, etc.
Try IFC
One of our big customers (25 licences) has done a full building in Hamburg in 3D+construction documentation in ArchiCAD. They gave the full BIM to Revit via IFC. Everything was inside, nothing missing!
2009-07-01 04:22 PM
2009-07-01 04:30 PM
2009-07-01 05:28 PM
				2009-07-01 08:46 PM
Holger wrote:Mr. Kreienbrink you are very self-assured... I put yesterday a very basic IFC problem, about window's reveal and actually, nobody seems to have an obvious answer. Do you? link
Yes and No, IFC is the modell (+ all 2D stuff in 2x3) and of course you would some PDFs for the full documentation.
And I doubt that it is possible for us to create a native import as the Revit format is not open. And I guess the dark side of the force is not willing to give us access to it
2009-07-03 08:40 PM
