Import GIS data to archicad
Hi All,
I am trying to build a 3D context model of existing and proposed building from GIS data from our city council. Does anyone have any idea how to go about this? There are a number of different formats that I can use to export the data.
I've also considered that I might be able to use Sketchup or rhino/grasshopper as a go between to translate the data into a 3D model if archicad is unable to do.
The data is located here for reference:
https://data.melbourne.vic.gov.au/Property/Development-Activity-Monitor/gh7s-qda8
Any help would be greatly appreciated.
Cheers, Jake
5 Replies 5
runxel
Looks like you can download a KML file, which Archicad should be able to read.
Thanks runxel, I'll give that a try and report back.
Cheers, Jake
Ok that's not working. If I try to open or merge the file I just get an error saying "Can not open 'file name'.kml"
Any other ideas?
runxel
There is also a .kmz – same thing but zipped. Try that?
Then there is GeoJson, but that is for 2D data only afaik. You can preview this data at least with https://kepler.gl/demo
For converting GIS data however you need something like QGis (free).
JSN
I would go for that option. I did not find your GIS Data but if you do it via Rhino or GH you have a high chance that you get what you fullfills your needs.
