Import object from Rhino to Archicad 19
I'm currently working on a computer which only has ArchiCAD 19, and I am trying to import a file from Rhino. However, I can't find any way to do this. However, I can't find any way to do this whatsoever. Is there any way? I don't care if it's a weird workaround or whatever, I desperately need to import this file. I know that 19 is an ancient version but a software upgrade is not a possibility here unfortunately.
1 Solution
Eduardo Rolon
Try multiple options: [list=]
  • 3DSout from Rhino -> 3DSIn in AC
  • [list=]
  • DWG from Rhino -> Open the DWG as an Object
  • [list=]
  • SKP out from Rhino -> SKP in AC
  • [list=]
  • Download a 24 30 day test, open Rhino, save object
  • Eduardo Rolón AIA NCARB
    AC29 US/INT -> AC08
    Go to post
    2 Replies 2
    Eduardo Rolon
  • [list=]
  • [list=]
  • [list=]
    AC29 US/INT -> AC08
    You can download both Rhino Importer and Exporter Add-Ons for AC18/19 from here:
    https://graphisoft.com/downloads/addons/interoperability/rhino#:~:text=Import%20Rhino%20Model%20to%2...)%20files%20directly%20in%20Archicad.
