No, it does not seem to show any information specifically about why those elements were not imported.
You could also try to open the IFC file in an IFC Viewer like Solibri Model Viewer, and see if that application brings in those elements. This step can help figure out if there is a problem with the IFC export from Tekla (in which case Solibri will not bring in the elements either), or it is an import problem in ARCHICAD (in case Solibri imports them but ARCHICAD doesn't).
