Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Imported .rva door has locked size
CosminF
Hi!
I received from a door supplier a .rfa file (Revit family object) of one of their products. I have imported it in Archicad with Import RFA as GDL Object function, all is well, except that the door has a fixed height and width, which I cannot seem to be able to edit.
I can edit the thickness attribute, and it does stretch the element, but I couldn't find a solution for my problem online (and I've been looking for some hours already).
Anyone have any experience with this?
Edit:
Size variables are also locked if I open the GSM Object.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
@CosminF ,
We are use to modify all parameters with Archicad objets but It does not deals with the same possibilities with RFA files.
I invite you to use Archicad objets instead of this RFA door because it possible.
Have a great day.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
8 REPLIES 8
Hello @CosminF ,
I am not sure importing a rfa file make it editable but are you able to share the 2D and 3D GDL scripts ?
I am sure you are able to use Archicad doors instead of this rfa file to get the better graphic rendering.
Christophe - FRANCE
CosminF
Hi Christophe!
How can one export the scripts? I have tried to copy-paste the contents into separate .txt files but those cannot be uploaded here, so I'm assuming there's a smarter way to do it.
@CosminF,
Please share here a drawing of your door and copy and paste 2d/3d scripts here or export a PDF from your txt file.
Christophe - FRANCE
PDF's are attached (unfortunately the 3D script has almost 110k lines)
Thank you for the help!
@CosminF ,
Sorry Archicad is able to import a éditable RFA file 🤗
This line into 2D script means 2D is a 3D projection : PROJECT2 3, 270,...
3D script is not as well done than an Archicad nativ script... What is about the part above the door. ?
Can you share the RFA file ?
Christophe - FRANCE
CosminF
The part above the door is the engine and rolling part (this is a vertically sliding door for a cold storage space).
Unfortunately I am not sure I can share the .rfa file as our project is NDA-bound currently and I do not want to put myself in a delicate situation regarding this.
I have already reached out to the supplier, to see if he can help with a more compatible BIM file, I just thought it could've been an easier fix..
edit: last-measure work-around would be to redo the object, export it in Blender, extrude its height and width and then re-import into Archicad.
@CosminF ,
Have a great day.
Christophe - FRANCE
CosminF
Ok, thank you very much for the support!
Setup info provided by author
