‎2017-07-13 10:55 AM
‎2017-07-13 12:02 PM
‎2017-07-13 12:37 PM
‎2017-07-13 01:38 PM
‎2017-07-13 02:40 PM
‎2017-07-13 07:33 PM
DGSketcher wrote:This is almost always what I do -- I haven't used the XREF function since the Drawing Tool was introduced.
I place the 2D DWGs on a worksheet using Drawing Tool. Make sure you match the scales when importing if you want the text heights to match. You can then select the drawing and use the Drawing Selection Settings window to adjust the pen colours and which layers are displayed. This method has the advantage of placing everything in AC under a single layer so you don't get layer name clutter plus once you have filtered out what you want you can explode the drawing and use what 2D elements you want to edit into your project.
‎2017-07-17 10:39 AM
‎2017-07-17 02:16 PM
another Moderator
