2021-04-15 07:30 PM
2021-04-15 08:56 PM
2021-04-16 10:02 PM
LaszloNagy wrote:Thanks for the reply. So if I add the objects to favorites, the classifications will carry over? This would work great if so.
I don't think this is possible to do the way you want it because Library Parts and Classification systems are two non-interdependent things in Archicad and either or both may or may not be present in the Project File at any time.
So, in order for this to work, you would first have to have the Classification System (and probably relevant Properties) imported into the Project File you want to use it, then the Library Parts must also be within either the Embedded Library or a Loaded Library of the Project, and then you would have to save Favorites of the Library Parts which would contain all the specified Classification and Properties and their values. You could then export-import these Favorites into the Project file and then when you have all these available in the File (Classifications, Properties, Library Parts, Favorites), then you could guarantee that, when you activate such a Favorite and use it to place such a Library Part, the Library Part has the correct Classification value and Properties and Property values.
2021-04-16 10:34 PM
