maurotrotta
Master Layout template object missing
I have a question about the objects that appear in the library by default. Long time ago, I could find in the library an object that help me doing the master layout. This template already had drawn the frames of the layout and it was possible to edit them through its settings. I don´t remember if it also include an title block but I think it did. I am using Archicad 26 now, and this object doesn´t appear. I look for info about this online but I don´t see anything about it.
Do you have access to one of your old files?
If so, that will tell you what the object is called.
I am not aware of any border or title block objects in the default library (just did a quick search).
It may have been a custom object from a 3rd party.
Or maybe open your default Archicad template and and see what is done there.
In the AUS template that I have it is all just text and lines - no objects.
