2023-02-08
05:33 AM
2025-01-30
12:25 PM
Aruzhan Ilaikova
Hi all,
I am trying to put together a FF&E schedule for our office template that orders objects by their location.
I know that a door schedule will pick up the location of a door based on the zone associated with a given door. Is it possible to achieve this with objects also?
See the images attached; I have placed several objects in a full storey height zone as a test, and have had no luck getting the schedule to identify the objects' locations.
Does anyone have any good suggestions on how I might get this to work?
Thanks in advance,
Ben
AC23-25
macOS 12
Solved! Go to Solution.
2023-02-08 07:08 AM
It's not clear which field parameters are being used in the screen shot schedule.
To Zone and From Zone won't work for objects.
It should be "Related Zone Name".
Architect | Graphisoft Certified BIM Manager
ArchiCAD 27 JPN USA & INT | Windows 10
2023-02-08 07:08 AM
2023-02-10 02:18 AM
Yep, changing the parameter to "Related Zone Name" does the trick - thanks!
