2007-10-31 05:16 PM
2008-02-07 10:49 PM
Karl wrote:If your philosophy is that the door should be numbered according to the 'from' side, than there is no problem because that is the way AC behaves; HOWEVER, if you want to comply with the National CAD Standard and have the door numbered according to the secure side of the door (which has nothing to do with door swing), then you have to manually number (NOT BIM) your doors to get them to schedule correctly.
The door swing always seems to show the proper 'from' zone for me ... just that, as you say, if the 'from' is the outside, then that is (correctly IMHO) blank. If you want to have a notion of 'outside', either put a footnote that blank means 'from the outside', or create a fake zone around the building for no purpose other than filling in the contents of that field?
So, I guess I'm not seeing any problems with how the schedule is behaving.
2008-02-07 11:43 PM
Laura wrote:Well, I guess I'm saying that ArchiCAD does what it is documented and designed to do.
2008-02-08 06:11 PM
vfrontiers wrote:The key being that the user chooses which room the door is associated with (it is not an assumption made by AC). Moving the identifier into the desired Zone got us half-way there, but the fact that the IS scheduled the door according to swing (not identifier) regardless was just plain wrong. I will post a wish...
On that note, then I propose a wish for a MOVEABLE HOTSPOT that associated the door with the room (I am thinking of something like the little cross for a ZONE)...
2008-02-08 06:31 PM
Karl wrote:The problem is (as Laura describes elsewhere) that there should be a ROOM that is related to the door but it isn't always the TO or the FROM... for example, in schools ALL CLASSROOM doors must swing into the hall, so if you used the TO room it all would read HALL. Yet janitor and other minor rooms would likely swing into their respective rooms.
Hey Duane,
Karl
2008-02-08 06:48 PM
2008-03-03 07:56 PM
2008-03-05 09:09 AM
Laura wrote:Can you elaborate? Working with a fix from Karl? or just in the recent HOTFIX?
ALL -- I just heard back from GS (again, via Karl) that the issue was a bit of bad code in the Zone Stamp's master script (which isreallyodd since the stamp worked in AC10). I'm very happy to report that my schedules are now working -- LJY.
2008-03-05 04:35 PM
vfrontiers wrote:
Also, I presume the link to the zone is not updated per our requests, and that it uses the swing to determine the zone affiliation?
2008-03-05 05:20 PM
Laura wrote:Can you post the stamp here?
A fix in the Zone Stamp GDL script as provided by GS (a misplaced command after a THEN statement, without the successive ENDIF -- if you must know). Karl was just the intermediary in my contact with GS.
2008-03-05 05:20 PM
