Is there a way to bring a dwg xref which in paper space uses
Is there a way to bring a dwg xref which in paper space uses xclip?
Djordje
You just want the clipped portion, right?
Use the Paperspace option in ArchiCAD, at 1:1, then resize to real size.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
1 REPLY 1
Djordje
Djordje
HP Omen
