We value your input!
Is there a way to export an elevation dwg as lines only. Whenever I export it is always as blocks!
Is there a way to export an elevation dwg as lines only. Whenever I export it is always as blocks and it is lagging autocad so hard. It is quite odd to me that I cant choose to export only as lines or maybe there is such an option. Can anyone help me with this?
Thanks guys!!!
Hello kyusuk1,
You are able to modify dwg export translators as you need :
https://helpcenter.graphisoft.com/user-guide/65980/
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
More specifically, try to set the "Saving Floor Plan" field to the "Explode Complex ARCHICAD Elements" option, see if that achieves what you are after.
