Is there a way to export an elevation dwg as lines only. Whenever I export it is always as blocks!
Is there a way to export an elevation dwg as lines only. Whenever I export it is always as blocks and it is lagging autocad so hard. It is quite odd to me that I cant choose to export only as lines or maybe there is such an option. Can anyone help me with this?
Thanks guys!!!
2 Replies 2
Hello kyusuk1,
You are able to modify dwg export translators as you need :
https://helpcenter.graphisoft.com/user-guide/65980/
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
More specifically, try to set the "Saving Floor Plan" field to the "Explode Complex ARCHICAD Elements" option, see if that achieves what you are after.
