Is this a schedule bug?
Hello
I have a schedule that behaves very strange. I want to list the different skin areas but as you can see in the attached picture Archicad (21) does not merge uniform items as it should. ( I don´t have two building materials with the same name and I have unchecked the End Surface: Overide... Has anyone experienced something similar?
3 Replies 3
Erwin Edel
Maybe the thickness is off by 0,01 or less mm? Are there any other parameters you are scheduling that could be different?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
They belong to the same wall composite structure, so all the parameters are the same
When deciding what is a uniform element, every scheduled data of and element is considered.
Since the Skin Areas are not exactly the same, they will not be merged into a single Schedule Cell.
