We value your input!
Layer display priority problem in dwg conversion;
I have a problem with layer visibility when i convert file to dwg/dxf.
In archicad everything is fine But in Autocad, annotations are going behind beams, walls etc. and I dont see another way than doing it manually in autocad but it is a lot of work for 20+ drawings
Also second problem is connected to first one, when i turn on true lineweight in autocad, half line of slab is fine and half is thinner and again I have to manually select it then hit draw order send to front and so on.
Is there a way to set priority on lines intersections, like annotations are in front of everything then slabs and beams first, then walls etc.
0 REPLIES 0
