Matvii_Bor
Line color export
Hi everyone!
I was trying to save pln as a DWG file. One problem is that part of the walls export in Black color (not as by layer). How can i fix it?
Hello @Matvii_Bor,
DWG is not a Graphisoft format so you have to consider how do you export it.
Into the file menu there is a interoperability menu in which you can find the dxf and dwg export parameters.
Into this menu you will find all the parameters your are able to modify to export your dwg as you want.
Export a dwg with color by layer is possible of course !
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
