Line weights on DWG
Is it possible to import a dog into Archicad and retain it's original line weight settings?
Eduardo Rolon
If you mean DWG you will place the DWGin AC but you will need to create a Pen Set that matches the line weights in the original file and assign it. AC cannot read the line weight settings from the DWG automatically.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Yes, I do mean .dwg not dog!
And thanks
Eduardo Rolon
Changed the title…
AC29 US/INT -> AC08
another Moderator
