Linetype-Linetype Conversion
If I understand correctly you can set what the archicad line types will plot to in dwg format. The problem we have encountered is we set archicad linetypes to plot to the hidden2 autocad linetype, but when the drawing is published the linetype are still set to continuous. Under the methods option, the "Set all elements to bylayer" is unchecked and the linetype scale is set to 1. Am I doing something wrong?
Sorry if this is in the wrong forum, new to these forums.
Thanks
0 Replies 0
