Hi everybody,
Is it intentional that you can't link properties to criteria when working in Teamwork?
Is there a workaround?
Also I believe I could tie properties to elements individually, but I can't do that anymore.
Is that a change in AC 19?
Cheers
It says what you need to do right there at the bottom of the Dialog.
You will need to move those files to the Embedded library. I guess it is talking about the Property Objects within the default ARCHICAD Library.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
