We value your input!
List / Elements
maro
List / Elements can be saved into View map but cannot be inserted into layout? is it limitation? Lists cannot work like Schedules?
Thanks
9 REPLIES 9
Just activate the Layout you want to place it onto, then switch to the View Map in the Navigator, then drag-and-drop the View to the Layout. It works for me.
maro
For me this dont work, see atached printscreen
AC 24 B 4007
Thanks
That is very strange.
Can you try if it works if you start a brand new project based on the default Archicad template? If it works there, then this problem may be file-specific.
maro
previous printscreens are from template 24
I figured it out.
There are two types of Lists: simple text lists and lists displayed based on a graphical template.
The former can not be placed onto Layouts, the latter can be.
maro
Ok, Thanks, I need insert simple text
is there simple graphical template for use like simple text
I dont time to set Format Wizard
Thanks
maro
for Fills used in section elevation I need template like is this simple text list
Is possible set the Format wizard like this?
Thanks
Sorry, I have not worked with Lists in the last 10+ years as I have been using Schedules.
maro
Schedules are better but have limitation for Fills from Sections and Elevations, can be this limitation fixed in AC 25?
Thanks
