2006-10-09 08:25 PM
2006-10-12 05:25 AM
Matthew wrote:I'm all for this. Once I get everything working like its supposed to be around here - I'll move into the export issue. :]
There's gotta be a way to go straight from BIM to the machines.
2006-10-12 07:35 AM
Dwight wrote:Cheese whiz! I guess I gots more vocabularies than I thawt.
"Moribund."
There's a word you don't hear every day.
2006-10-12 09:21 AM
sirduncan wrote:If, as the Revit guy says, IFC is the solution, it should work just as well with Archicad!
Now - about that exporting to ADT thing . . . . . . . . . . :]
2006-10-12 06:52 PM
Thomas wrote:I concur - now its off to figure it all out.
2006-10-13 09:45 AM
Scott wrote:Same as from Archicad ...sirduncan wrote:I haven't tried this, but I've heard IFC is the way to go. Export an IFC model from Revit, import IFC to ADT.Thomas wrote:So I'm finding. Thanks. Anyone know where I can get a difinitive answer on this issue?
- My sources tell me Revit files are NOT compatible with ADT.
Otherwise, you can export from Revit to 3D DWG, and open the 3D model in ADT, but there is no "intelligence" in the model. It's simply 3D forms.
