		2020-05-06
		04:33 PM
		2022-05-16
		02:26 PM
			Rubia Torres
2020-11-01 01:18 AM
2020-11-04 02:21 PM
bouhmidage wrote:Hello,
The SAF format inspired me, this logic could be used in MEP in other sort,
MEP elements are " a block " with connections, inputs and outputs, a common format between all MEP softwares, that scribes theese inputs and outputs and " the block itself"
Inputs : common input parameter ,
Output ; Common output parameter
Block : geometry convertion
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-11-04 02:32 PM
2020-11-04 05:17 PM
Moonlight wrote:
@bouhmidage
Where can we consult SAF format ??
2020-11-04 06:28 PM
2020-11-04 06:50 PM
2020-11-05 10:15 AM
Thanks Mnguyen
Maybe like that it's more clear !
Minh Nguyen
GRAPHISOFT
2020-11-05 12:10 PM
2020-11-05 02:39 PM
2020-11-05 03:53 PM
