ā2020-05-06
04:33 PM
ā2022-05-16
02:26 PM
Rubia Torres
ā2021-06-02 04:47 PM
ā2021-06-07 04:08 PM
ā2021-06-07 09:12 PM
ā2021-06-08 10:57 AM
ā2021-08-04 09:03 AM
gpowless wrote:Have to agree, this is really annoying. At some vertical range elements just won't be showed on a floor plan. After placing it on a floor plan or 3D view element present in 3D. But you won't find it on floor plan (this, above, under). At least, it's hard to find. Though after 'ctrl+A' you'll see hotspots for this element (duct/pipe).
Please fix the angled duct that disappears in plan.
Please fix the jumping stories issue. MEP should automatically be placed on the story that visible even if the story offset is selected for another storey. ie When a duct is placed with an offset to an upper storey then it should be immediately visible on the storey it was created on.
ā2021-08-04 09:51 AM
ā2021-08-04 10:27 AM
A. wrote:This seems to be a new "feature" across the AC tools. I have had it more frequently in recent AC versions where it is possible to place an elements outside the current view and then be greeted with the Undo option. I don't think it is a good move, after all, we usually draw something where we expect to see it.gpowless wrote:Have to agree, this is really annoying. At some vertical range elements just won't be showed on a floor plan. After placing it on a floor plan or 3D view element present in 3D. But you won't find it on floor plan (this, above, under). At least, it's hard to find. Though after 'ctrl+A' you'll see hotspots for this element (duct/pipe).
ā2022-05-16 12:49 PM
As engineers we often have a need to model sewer-, water-, storwater drainage systems. It would be a blessing if you included library for PVC-/Concrete pipes, ductile and PEH waterpipes as well as manholes, manhole covers etc. in order for us to model entire water and sewer utility systems. There are in fact many available librarys for Revit, maybe they could be easily converted and used for Archicad MEP? As a bonus it would be handy if you could start from a manhole with the right top and bottom level, entry and exit level for pipes with diameter and slope, as well as lenght input. To complete please also ad the possibility to specify the trench dimension and various fill as bedding for pipes.
