2017-04-06 04:13 PM
2017-04-06 04:17 PM
Eli wrote:
I have some pipework that disappears on plan when the end elevation is set past a certain height below slab.
My floor plan cut plane is set to show 3 stories below, offset by -5000 mm. The pipe is set to show on all stories. Renovation filters are not affecting it.
In 3D if I raise the end elevation of the pipe as shown in the attached screenshots, it appears in plan. When I lower the end of the pipe below a certain elevation, it disappears on plan, but can still be selected and still shows the end grips as seen in the attached screenshot.
2017-04-06 04:59 PM
2017-04-07 01:12 PM
2017-04-07 01:14 PM
gpowless wrote:
There are a lot of issues with MEP and it seems one of those things that has dropped off Graphisoft's radar. Disappearing sloping pipes/ducts is just one of many things that doesn't work right.
I find that ducts and pipes jump stories disappearing sometimes on 1 or 2 stories away from their origins. Using All Stories or One storey Up/Down seems to compound the issue. Changing duct or pipe specific visual properties wipes out the system they belong to and sets them "undefined". I could go into a lot of it but suffice to say that despite Graphisoft's move to 3D working & documentation shift MEP isn't it.
2017-08-20 09:23 AM
2017-08-21 03:57 PM
alemanda wrote:I'm not sure I understand. The pipe object does not have a symbolic display option.
what about setting the display as symbolic instead of all relevant stories?
2017-08-21 04:03 PM
2017-08-29 01:33 PM
alemanda wrote:Ah, thank you!
you have symbolic view.
CTRL+T to open settings of your pipe part.
See "all parameters"
Go to "2D representation" and enable the symbolic view.
