Numbers format in schedule cell
is there a way to change the format for numbers in cell?
for instance, adding a point as thousands marker.
12 REPLIES 12
alemanda
I think it depends on the international settings in you operating system.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Already checked, Archicad doesn't take the format from them.
Eduardo Rolon
FYI, in MacOS X it does.
Don't know about Windows.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
I'm using Mac OS X and it isn't getting the format from the international settings. Anyway it should be editable my settings are not necessarily the way the client is asking for their schedules
Eduardo Rolon
Sadly it cannot be controlled separately.
Under Preferences ->Language and Region->Advanced->…
Restart Archicad for changes to take effect
There you can add any item as a thousands separator provided though AC might just recognize the basic ones (, . ')
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
AC28 US/INT -> AC08
another Moderator
Eduardo Rolon
and in AC.
FYI, this is where I change my short date to match 20XX-XX-XX
AC28 US/INT -> AC08
another Moderator
Eduardo, thanks for the tip, but my setting was already the way i needed to be, the problem is AC not getting them.
I´m using the standard "cost" parameter from basic AC library parts, when i try to write the cost of a product using the point AC deletes it automatically.
When it comes to other numeric parameter like Area, it works perfectly with the thousand mark.
This is another schedule using area from zones
