2017-10-13 08:41 AM
2018-05-23 09:58 AM
2018-05-23 10:10 AM
2018-10-30 09:22 PM
2018-10-30 09:38 PM
2018-10-31 09:30 AM
Mats_Knutsson wrote:Hi,
Tried 22 and no luck...whazzup?
2018-10-31 11:25 AM
dkovacs wrote:I tried AC22 SWE full 4018. No textures on the surfaces.
The issue with obj file export, that the materials got messed up should be fixed in AC21 60xx and AC22 30xx.
Did you find that it still messes the materials up for you the same way in the new version?
Or do you experience a new error?
Regards,
2018-11-06 01:41 PM
2018-11-07 03:44 PM
dkovacs wrote:AC22 SWE full. Latest update. I use Sketchfab for viewing. When I export obj I get the concrete material but not the brick (both png) I zipped the obj+mtl+texture folder into one zipfile and in Sketchfab I can manually relink the textures but that's not interesting. When I export as fbx textures are fine but the model is rotated.
Hello Again,
I tried AC22 INT on W10. I opened the exported OBJ file with the default Microsoft 3D Viewer application, and it seems to be fine for me...
Regards,
- What application are you using for opening the obj file? (maybe that application can't display materials at all?)
- What does the result look like for you?
2018-11-08 02:04 AM
2018-11-08 08:41 AM
Barry wrote:Sherlock Kelly, you're right. It's only the override surface that exports applied to the element.
I haven't tested this but I am wondering if when saving as OBJ, is it using the wall surface override rather than the building material, or maybe it is the other way and it is using the building material rather than the surface override.
I am wondering it it is using one or the other regardless of how the wall is actually set to display in Archicad.
