Object Information in Schedules and Lists
I would like to create a plumbing fixture schedule that show the fields i have filled in for the item...
i.e. toilet, sink, bathtub : manufacturer/cost/finish etc.
any suggestions?
5 REPLIES 5
TomWaltz
Have you tried the Interactive Scheduler yet?
Tom Waltz
yes.
ive looked at it, but i cant find the cost/manufacturer/.... parameters to add to the list.
TomWaltz
It's not under the ArchiFM & Listing Parameters?
Which objects are you using? Looking through the Archicad library, all the objects I could find had these parameters.
Tom Waltz
This question belongs in the Calculate forum...
In any case: all parameters can be scheduled... look under "Additional Paramters" when adding Fields in the Interactive Schedule.
found it!
much appreciated and thank you!
