2021-09-22
02:36 AM
- last edited
3 weeks ago
Molinda Prey
Hi All,
Have any of you experienced or be able to replicate this bug?:
Check the video
2021-09-22 04:37 AM
Interesting. I will report this to Graphisoft.
2021-09-29 09:20 AM
Dear Nando,
Thank you very much for the report and I am very sorry about the issue!
I tried to replicate the issue using Archicad 24 INT 6004, but it works correctly in my case. May I ask which Archicad language version you use, and did the issue happen with the latest update installed?
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-09-29 02:30 PM
Thanks Nguyen,
I just tried again, and can replicate in:
Hope that helps
2021-09-29 03:20 PM
Hi Nando,
Thank you very much for the information! This is very helpful!
I found that, with the default AUS template, the option Uniform Window Surfaces is enabled. This is the reason why the surface got changed when you set the ID. Seems like this attribute was "reset" to match with the other surfaces set in its settings. Thus, the workaround in this case is to disable Uniform Window Surfaces option
I believe this is a bug, so I will enter it into our defect database. Thank you very much for the report once again, and have a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
2021-09-30 04:14 AM
Behaves like a bug: it actually only happens once with objects, next time - and if you switch on/off the "Uniform Surfaces" options, then it won't happen again.
Regards
2021-09-30 01:17 PM
Dear Nando,
Thank you very much for your finding! I have added it into our defect entry (please refer to it as DEF-6510).
I wish you a great day!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
