ā2008-04-04 11:37 AM
ā2008-04-04 01:54 PM
another Moderator
ā2008-04-04 02:38 PM
ejrolon wrote:Do it on what?
command+I?
ā2008-04-04 02:51 PM
Mac OS X 10.5: Finder may restart when trying to change file permissions
Last Modified on: December 10, 2007
Article: 307128
Issue or symptom
āØWhen trying to change file permissions in a Finder Get Info window, the Finder itself may restart after the "+" button is clicked.
This issue can affect accounts that were migrated from Mac OS X 10.4 Tiger.
āØProducts affected
āŖ Mac OS X 10.5
1. Log in as an administrator.
2. Open Terminal (in /Applications/Utilities).
3. Type the following commands, each on a single line and followed by Return (enter an admin password when prompted):
sudo dscl . create /Groups/username GroupMembership username
sudo dscl . change /Groups/username RecordName username _username
āØReplace the italicized "username" with your account username (which is also the name of the user's Home folder, in the Users folder). Remember to include the underscore "_" before your user name in the second command.
If you have more than one account on the computer affected by this issue, you should run these two commands again for each account, substituting with the appropriate user name each time.
This document will be updated as more information becomes available.
another Moderator
ā2008-04-04 06:38 PM
ā2008-04-04 10:01 PM
another Moderator
ā2008-04-04 11:01 PM
Thomas wrote:Hi Thomas,
I just upgraded from OSX 10.4.11 to 10.5.2. Everything works fine, printing is much improved, etc except one thing:
Archicad refuses to load Objective. I've got Objective 11 2.0.2. Worked fine previously, but not in Leopard. I changed the file permissions on the Objective folder and its contents to full R/W for All, but it doesn't help. Should I change name of the Objective.bundle to Objective.apx? Or is it some other known issue?
This is Archicad11 Int and Swe with hotfix 1200.
ā2008-04-05 01:28 AM
ā2008-04-05 01:35 AM
jespizua wrote:Then you'd better change your signature
I“m using objective with the same system as you and no problem here.
ā2008-04-05 01:46 AM
Ralph wrote:Thanks Ralph, I posted here instead of contacting you because I had a hunch something like the permissions issue, not related to Objective, would be the culprit. I have 2.02 as I posted.
Do you have OBJECTiVE 2.02 or the latest version 2.12? By the way, you can contact us directly if you have problems like this. For the record, OBJECTiVE has been tested with this configuration without problems.
