Emre Senoglu
Opening GDL in Rhino 6
As far as I can see, the GDL Converter for Rhino is non existent for Rhino 6. So how does one open GDL objects in Rhino 6? I am not speaking about grasshopper, but just plain custom made gdl objects. Thanks
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
3 Replies 3
Do you want to get the geometry of the GDL Object into Rhino?
You should use Deconstruct Components of the ARCHICAD-Grasshopper Connection.
Emre Senoglu
Hey Laszlo thanks! I'm no GH wizard, so I'm probably setting it up wrong but all I'm seeing is a bounding box...
Emre Senoglu
also what's up with this?
