Organize Schedules
Is there anyone who know if there is possible to organize a schedules?
Or is it impossible?
Look at my picture, I would like to organize diffrent as ArchiCAD is doing.
5 Replies 5
Eduardo Rolon
In the Schedule Scheme settings click on the arrow for that parameter and clear the others.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Okey I understand, but there is no way that I can do it manually?
Thx for the answer 😃
Apart from changing the width of the cells you can't do anything manually.
But you can set your schedule so that it is horizontal or vertical, you can arrange in ascending/descending order, you can arrange the order of your fields, you can get sum totals, you can group headers and more.
There are quite a few things you can set up as default - and of course you can change these settings at any time.
What do you want your schedule to look like?
Erika Epstein
You can manually rearrange the parameters. In the Scheme Settings on the Fields (bottom) click on the up/down arrow on the left to drag.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thank you Erika, Barry and ejrolon for your help
