Apart from changing the width of the cells you can't do anything manually.
But you can set your schedule so that it is horizontal or vertical, you can arrange in ascending/descending order, you can arrange the order of your fields, you can get sum totals, you can group headers and more.
There are quite a few things you can set up as default - and of course you can change these settings at any time.
What do you want your schedule to look like?
